can you read knk with s-afcII?
on my car if i leave the afc in monitor mode it reads nothing from knk witch i think is nock but if i put it in sensor check mode it reads knk. in check mode it shows the posible knk value can be as high as a four didget number. my question is does this number in sensor check mode mean anything? and if so what is normal?
knock really doesn't work on evo...
they work but they're fairely all over the place. I don't even look at it anymore.
supposely it uses the voltage frequency to determine the knocks but really, it's more of a headache than anything.
normal is suppose to be, after you set the knock setting, 0-35 is normal, then anything after that is a sign of a knock.
but when your car knocks, you'll know.
