Autronic PnP board for Evo IX?
#140
We just put in the cosworth 272 cams, 1008cc injectors on my IX and the idle is smooth and better than stock. The car pulls like a freight train and is pretty scary with the Carbonetics twin disk clutch holding the power. We should be hitting the dyno (dyno dynamic) in a week or two to clean up what we could not hit with road tuning. I will definitely keep you up to date on what we hit if you are interested.
-Tay
-Tay
#148
unfortunately, there is NO knock control for any autronic ecu. it's been "coming" for some time (i have a standalone sm4). a quick call to ray hall will confirm this. what makes it confusing is that even though it is not available autronic refuses to stop advertising it, even on their home page for the sm4.
#149
That is because knock control module is already under development for some time. There are some specific troubles that have to be solved, like different knock sensors on different cars and different frequencies of knock.
That is why I told you that J&S is working perfectly. Unimaginable good I could say.
You just put like 30deg in whole ignition table and let the J&S do the rest. It will retard timing per cylinder basis and keep the best ignition angle under control, no matter what is written in the table! Great stuff!
#150
