went tuning for 3 hours...heres what i did...
Old Aug 18, 2005 | 02:14 PM
rraulston's Avatar
Tuned for 3 hours today. Its 90 degrees out and ime using 100 octane.....
Code:
    	     	     	   	Load	Knock	      	      	 Mod	  Mod	      	  Mod	  WB
 RPM	  MAP	  MAF	TPS	Site	Count	 Ign#1	 Inj#1	 Ign	  Fuel	Boost	  MAF	  AFR
    	  psia	  Hz	 % 	    	     	  deg 	 duty 	 deg	   %  	(OL) 	   Hz
847	-4.5	42	0	0	0	13.3	1.4	ECU. 	7	ECU.  	46	14.92
847	-4.5	42	0	0	0	13.3	1.4	ECU. 	7	ECU.  	49	14.92
846	-4.5	42	0	0	0	12.3	1.9	ECU. 	7	ECU.  	44	14.83
853	-4.5	42	0	0	0	14.2	1.5	ECU. 	7	ECU.  	44	14.78
2574	-5.2	132	15	0	0	40.7	6.2	ECU. 	0	ECU.  	151	14.58
2594	-5.2	139	15	0	0	40.7	6.3	ECU. 	0	ECU.  	190	14.58
2614	-4.5	301	33	0	0	26.6	48.6	ECU. 	0	ECU.  	328	14.65
2614	-3	315	100	10	0	20.5	13.7	20.1	16	75	386	13.84
2688	-1.4	327	100	10	0	18.4	14.5	20.1	16	75	379	12.37
2743	0.3	351	100	10	0	18.4	15.6	20.1	16	75	413	11.65
2775	1.5	379	100	10	0	17.4	16.7	20	16	75	391	11.62
2829	2.1	401	100	10	0	17.5	18.2	19.8	16	75	463	11.58
2891	2.8	424	100	10	0	15.3	19.2	19.6	16	75	488	11.58
2973	3.5	461	100	10	0	14.7	20.6	19.3	16	75	548	11.65
3046	4.2	494	100	10	0	13.6	22.4	19	16	75	578	11.73
3095	4.9	524	100	10	0	12.5	23.2	18.8	16	75	690	11.81
3177	5.5	566	100	10	0	11.5	25.8	18.4	16	75	708	11.92
3290	6.4	610	100	10	0	11.4	28.3	18.1	16	75	599	11.98
3353	7.3	641	100	10	0	10.5	31.4	18.1	16	75	744	11.81
3475	8.2	719	100	10	0	9.1	33.3	18.1	16	75	651	11.61
3557	9.4	783	100	10	0	8	37.1	17.9	16	75	1168	11.45
3663	10.6	892	100	20	0	7.4	44	13.3	16	75	1082	11.49
3800	12	1026	100	20	0	7.7	50	13.2	15.1	75	1288	11.61
3930	13.6	1213	100	30	0	7.9	52.5	12.9	4	75	1373	11.45
4079	15.6	1278	100	40	0	7.8	58.9	12.4	3	75	1562	11.37
4268	17.9	1319	100	50	0	7.7	59.5	11	3	75	1572	11.37
4456	19.6	1305	100	60	0	7.8	59.3	10.4	4.6	75	1623	11.45
4597	21	1385	100	60	0	7.9	63.8	10.3	6.2	75	1488	11.84
4755	21.6	1461	100	70	0	7.9	67.5	10.4	8	75	1506	11.87
4901	22.1	1529	100	70	0	8.6	70.7	10.6	8	75	1562	11.53
5058	22.3	1562	100	70	0	8.7	72.7	10.9	8	75	1712	11.39
5216	22.6	1592	100	80	0	9.8	71.8	11.3	7.4	75	1736	11.37
5385	22.6	1650	100	80	0	10.1	74.8	11.5	7.5	75	1748	11.45
5518	22.3	1694	100	90	0	11.1	75.5	11.6	7	75	1923	11.45
5659	21.9	1706	100	90	0	11.2	77.5	13.7	7	75	1923	11.48
5817	21.4	1730	100	90	0	12.3	78.7	14.6	7.3	75	1838	11.52
5984	20.9	1779	100	100	0	12.2	81.7	14.7	9	75	1908	11.45
6116	20.5	1824	100	100	0	12.2	83.6	15.4	9	75	1865	11.39
6265	20.2	1831	100	100	0	13.4	84.1	16.2	9	75	1851	11.34
6373	20	1845	100	100	0	13.5	85.7	17.7	9	75	1893	11.33
6523	20	1872	100	100	0	14.5	85.6	19	9	75	1851	11.34
6640	19.5	1879	100	100	0	15.5	87.3	19.2	9	75	1923	11.33
6761	19.3	1886	100	100	0	15.5	87.4	19.5	9	75	1851	11.27
6872	18.9	1893	100	100	0	15.7	87.5	19.6	9	75	1908	11.27
7002	18.9	1901	100	100	0	16.3	88.9	19.8	9	75	1923	11.33
7137	18.9	1886	100	100	0	16.3	88	20.2	9	75	1923	11.34
7183	18.6	1915	100	100	0	17.6	88.5	20.6	9	75	1923	11.39
7342	18.4	1937	100	100	0	18.6	89.5	20.9	9	75	1923	11.45
7407	18.2	1923	100	100	0	19.6	90.2	21	9	75	1923	11.49
Any constructive comments are, of course, welcomed!! ray
Old Aug 18, 2005 | 02:28 PM
BJai02's Avatar
I think it is a good idea to adjust your MAX MAF higher so you will only be at 90% load site at redline. That will give the UTEC more room to run in a proper cell when teh weather change enough to affect the amount of air being sucked in (read 100% load site).
You need a bit more fuel between 4500-4750.
Seems like you are running in 3rd gear... if you are running stock turbo, it seems to spool a bit slow. You may want to try to "decrese" your gain by 1-2 point. But becareful that it will affect your boost level as well.
I envy your timing curve though. With 91 octane, I am riding on the knock threshold at 13 degrees, 20 at 7000 RPM. And I could only have around 5.5 deg between 4250-5250 RPM.
Old Aug 18, 2005 | 02:29 PM
rraulston's Avatar
trying to get the format right.........
Old Aug 18, 2005 | 02:34 PM
rraulston's Avatar
it is the stock turbo, and i dont know why it spools slow. I have a Halman. It never used to. I plumed in the TXS bleed valve on the Halman thinking that if i bled air off of the wastegate line, it would stay shut longer, but didnt seem to make a difference. Ime pulling 1900 Hz of and and the car runs very good, but the boost ramps slower than the EVC 5 i used to have.....
Old Aug 18, 2005 | 02:38 PM
BJai02's Avatar
You don't want the bleed valve (ABC) when you running Hallman. I think that's the problem.
Old Aug 18, 2005 | 02:53 PM
rraulston's Avatar
Here is the log without the TXS/ABC. You see, the theory is that if you were to increase the hole in the Halman, you would keep the WG closed tighter longer and increase the boost ramp rate. So instead of drilling out the small hole in the barb, i just plumed in the ABC and could effectly adjust the bleed rate. It worked soo well for Abner, he get a CEL everytime he boosts because he ramps too fast. Mine didnt. Anyway here is a log that i started the morning out with WITHOUT the ABC
Code:
923	-6.3	34	0	0	0	8.1	1.2	ECU. 	7	ECU.  	34	14.58
916	-6.3	34	0	0	0	8.1	1.2	ECU. 	7	ECU.  	35	14.58
945	-6.3	33	0	0	0	10.8	1.2	ECU. 	7	ECU.  	39	14.58
929	-6.3	33	0	0	0	9.1	1.2	ECU. 	7	ECU.  	40	14.58
2472	-1.9	197	21	0	0	32.5	7.8	ECU. 	0	ECU.  	190	14.61
2482	-1.9	203	21	0	0	32.5	7.9	ECU. 	0	ECU.  	201	14.61
2517	-1.9	287	27	0	0	27.6	11.5	ECU. 	0	ECU.  	336	14.58
2562	-1.2	320	61	10	0	19.5	13.2	20.1	16	75	378	14.65
2664	-0.4	343	98	10	0	17.4	14.4	20.1	16	75	482	13.47
2701	0.8	359	100	10	0	17.4	15.2	20.1	16	75	385	12.33
2801	1.9	386	100	10	0	17.4	16.8	20	16	75	469	12.02
2863	2.4	423	100	10	0	16.4	18.1	19.8	16	75	543	12
2942	2.9	443	100	10	0	15.4	19.6	19.4	16	75	474	11.93
3019	3.6	484	100	10	0	14.7	21	19.1	16	75	544	11.89
3092	4.3	503	100	10	0	13.5	22.2	18.8	16	75	551	11.98
3180	5	539	100	10	0	12.5	24.3	18.4	16	75	636	12.02
3306	5.9	641	100	10	0	11.5	28	18.1	16	75	618	12.06
3394	6.8	645	100	10	0	10.5	30.3	18.1	16	75	755	12.06
3508	7.6	701	100	10	0	9.4	33.6	18.1	16	75	1054	11.87
3642	8.7	814	100	10	0	6.7	36.3	17.7	16	75	1016	11.68
3741	10.2	943	100	20	0	6.6	45.6	13.1	15.7	75	939	11.73
3875	11.5	1082	100	20	0	7.1	51.5	13.6	14.5	75	1582	11.81
4040	13.2	1219	100	30	0	7.1	55.5	13.4	4	75	1101	11.53
4214	15.6	1377	100	40	0	7.1	61.2	12.4	3	75	1524	11.11
4415	17.9	1436	100	60	0	7.1	65.4	10.4	4.2	75	1655	11.12
4591	20.7	1533	100	60	0	7.7	69.4	10.3	5.6	75	1592	11.33
4782	22.8	1557	100	70	0	8.2	73.7	10.5	8	75	1824	11.43
4930	24	1633	100	80	0	8.4	75.9	10.7	7	75	1785	11.43
5144	24.2	1639	100	80	0	8.5	77.1	11.1	7.2	75	1811	11.28
5282	23.6	1736	100	90	0	9.9	75.2	11.5	7	75	1785	11.24
5482	23.1	1773	100	90	0	11	77.5	11.6	7	75	1824	11.33
5668	22.4	1805	100	100	0	11.1	79.2	13.7	8	75	1785	11.53
5837	21.9	1805	100	100	0	12.1	80.3	14.6	8.3	75	1923	11.73
5973	21.7	1858	100	100	0	12.4	81.4	14.7	9	75	1893	11.62
6138	21.9	1886	100	100	0	13.4	83	15.7	9	75	1923	11.53
6301	21.2	1901	100	100	0	13.4	85.1	16.9	9	75	1923	11.53
6485	20.9	1893	100	100	0	14.6	85.9	18.4	9	75	1908	11.49
6600	20.5	1923	100	100	0	14.5	86	19.2	9	75	1851	11.52
6775	20	1915	100	100	0	15.6	86.6	19.5	9	75	1923	11.49
6901	20	1945	100	100	0	16.4	87.5	19.6	9	75	1879	11.49
7002	19.8	1945	100	100	0	16.4	87.6	19.9	9	75	1923	11.49
7122	19.5	1937	100	100	0	17.5	86.3	20.4	9	75	1923	11.49
7246	19.1	1930	93	100	0	18.7	86.7	20.9	9	75	1923	11.52
Thanks for the insight..........Ray
Old Aug 18, 2005 | 03:15 PM
EvoVIIIFL's Avatar
I'd watch out on that Injector Duty cycle.. hittin nearly 90% is to close in my book...
Old Aug 18, 2005 | 03:43 PM
BJai02's Avatar
Talk about injector duty cycle. I see your signature saying 780cc injectors. i thought it should be big enough even for some big turbos? I was wondering how you are running at 90% duty cycle at only 11.49 AFR, 18.2 psi @ 7400 RPM.
I have the stock injectors, but I only hit 89% with 11.0AFR, 20psi @ 7200RPM. Someone pleae chme in... or I will have to look into a replacement of my oxygen sensor (I use LM-1).
Old Aug 18, 2005 | 04:39 PM
MalibuJack's Avatar
I definitely find my boost spools faster than that.. an MBC pretty much shuts off the signal to the actuator until the ball-spring tension is met, then it sends the signal to open the actuator, so in theory spool should be as quick as it gets... Is there some sort of restriction going on somewhere? I get that CEL also when the boost comes on.
Your injector duty is actually pretty high for 780cc injectors, but that may not be an issue, just tuning..
Here's a thought, as the boost ramps, you very quickly hit 11.5:1, and you have aggressive timing, what if you try running 9 degrees of timing, and lean it out a bit at lower RPM till you hit peak boost/torque... That may get the car to spool faster..
Old Aug 18, 2005 | 05:04 PM
rraulston's Avatar
my bad, i havnt updated my sig in awhile. They are stock injectors......I just cleaned the halman and the BOV. It was quite gummy. Ime going to go do another pull. If the boost ramps slow again, i will clamp off the WG line. If it still ramps slow, maybe a weak WG spring?? More in a few hours....Ray
Old Aug 18, 2005 | 07:06 PM
rraulston's Avatar
o.k., well ime stumped. I disconnected the WG line and did a log....Here it is. How is it possible that it ramps up so slow??????
Code:
809	-5.8	36	0	0	0	8.9	1	ECU. 	0	ECU.  	31	14.83
782	-5.6	31	0	0	0	8.9	1	ECU. 	0	ECU.  	31	14.83
805	-5.6	32	0	0	0	13.1	1.6	ECU. 	0	ECU.  	32	14.65
794	-5.4	36	0	0	0	9.9	1	ECU. 	0	ECU.  	33	14.58
2207	-9.1	61	9	0	0	32.5	3.4	ECU. 	0	ECU.  	61	 >25:1
2223	-9.1	58	9	0	0	32.6	3	ECU. 	0	ECU.  	61	 >25:1
2219	-8.5	262	20	0	0	33.5	14.8	ECU. 	0	ECU.  	327	16.69
2192	-6.5	278	100	10	0	23.2	10.8	ECU. 	0	ECU.  	276	15.5
2295	-4.2	264	100	10	0	21	9.9	ECU. 	0	ECU.  	259	13.39
2345	-1.8	307	100	10	0	20.4	10	ECU. 	0	ECU.  	290	12.39
2417	0.5	269	100	10	0	18.4	11.5	ECU. 	0	ECU.  	308	13.23
2447	1	301	100	10	0	18.4	11.7	ECU. 	0	ECU.  	329	13.84
2510	1.5	351	100	10	0	19.1	11.6	ECU. 	0	ECU.  	314	13.84
2550	1.9	366	100	10	0	19.8	11.9	ECU. 	0	ECU.  	305	13.92
2658	2.4	350	100	10	0	19.5	14.3	ECU. 	0	ECU.  	433	14.05
2718	2.6	394	100	10	0	19.5	14.4	ECU. 	0	ECU.  	430	13.84
2770	3.1	450	100	10	0	18.5	19.5	ECU. 	0	ECU.  	425	13.31
2873	3.6	424	100	10	0	18.5	19.1	ECU. 	0	ECU.  	484	12.81
2936	4.2	539	100	10	0	18.6	22.8	ECU. 	0	ECU.  	469	12.33
3003	4.7	512	100	10	0	17.4	25.3	ECU. 	0	ECU.  	491	11.8
3097	5.4	617	100	10	0	16.5	23.1	ECU. 	0	ECU.  	628	11.2
3220	6.1	572	100	10	0	13.6	27.1	ECU. 	0	ECU.  	634	11.02
3287	6.9	754	100	10	0	13.7	32.7	ECU. 	0	ECU.  	803	11.39
3436	8	737	100	10	0	11.6	34.4	ECU. 	0	ECU.  	687	11.53
3531	9	741	100	10	0	9.3	39.9	ECU. 	0	ECU.  	677	11.45
3642	10.4	1089	100	20	0	8.6	44.4	ECU. 	0	ECU.  	711	11.37
3770	12.2	1302	100	20	0	7.8	50.9	ECU. 	0	ECU.  	1219	11.33
3912	14.1	956	100	30	0	7.8	59	ECU. 	0	ECU.  	1529	11.28
4115	16.7	1552	100	40	0	7.8	64.5	ECU. 	0	ECU.  	1689	11.3
4301	19.5	1700	100	50	0	7.8	71.4	ECU. 	0	ECU.  	1650	11.23
4456	21.9	1612	100	60	0	7.8	74.4	ECU. 	0	ECU.  	1567	11.06
4655	24.2	1666	100	80	0	7.6	77.5	ECU. 	0	ECU.  	1677	11.05
4803	25	1766	100	80	0	8.3	80.8	ECU. 	0	ECU.  	1706	11.14
5035	25.9	1886	100	90	0	8.7	81.4	ECU. 	0	ECU.  	1858	11.17
5232	26.3	1805	100	100	0	10	82.8	ECU. 	0	ECU.  	1838	11.17
5437	25.9	1851	100	100	0	11	81.6	ECU. 	0	ECU.  	1792	11.2
5583	25.4	1792	100	100	0	11.1	82.8	ECU. 	0	ECU.  	1818	11.33
5757	24.3	1792	100	100	0	12.2	86.8	ECU. 	0	ECU.  	1754	11.45
5920	23.1	1937	100	100	0	12.1	88.7	ECU. 	0	ECU.  	1879	11.45
6071	22.8	1831	100	100	0	12.2	88.1	ECU. 	0	ECU.  	1838	11.34
6218	22.4	1779	100	100	0	13.3	84.5	ECU. 	0	ECU.  	1915	11.3
6385	21.9	1923	100	100	0	14.4	88.2	ECU. 	0	ECU.  	1851	11.37
6535	21.4	1945	100	100	0	14.4	87.2	ECU. 	0	ECU.  	1976	11.52
6666	20.9	1901	100	100	0	15.4	81.9	ECU. 	0	ECU.  	1976	11.67
6788	20.5	1930	100	100	0	15.5	85	ECU. 	0	ECU.  	1893	11.71
6958	20.7	1865	100	100	0	16.3	87	ECU. 	0	ECU.  	1968	11.71
7047	20.3	1908	100	100	0	17.3	92.3	ECU. 	0	ECU.  	1865	11.77
7168	19.8	2000	100	100	0	18.6	91.3	ECU. 	0	ECU.  	1886	11.81
Old Aug 18, 2005 | 07:17 PM
SlowCar's Avatar
You think 90 is bad....i once had 99.9...then - - -...i think the injectors stayed open!
Old Aug 18, 2005 | 07:28 PM
SlowCar's Avatar
ray, i have a theory...dont know if it'll fly......its really humid right now.....atomic weight of water H2O = 1+1+16 =18, nitrogen = N2 = 2(14) = 28. Since air is 78% nitrogen, 21% oxygen, ....the water in the air is making the atmosphere less dense (barometric pressure always drops when it is about to rain), less dense air = less/slower boost.
18/28 = 64%...the air is only 64% as dense as when the air is dry...also, sahuarita is higher elavation, so it doesnt help too.....
Old Aug 18, 2005 | 09:00 PM
MalibuJack's Avatar
Thats possible with air density and elevation.. also your wastegate may be opening (not enough preload on the actuator).. Another not so happy possibility is a problem with the turbo, maybe a bearing or lubrication problem causing it to not spin as easily.. Don't know how you would test for that though.. Another possibility is a leak somewhere or the MBC is gummed up badly that its always open slightly..
Old Aug 19, 2005 | 06:21 AM
EvoTech's Avatar
FYI. You are giving up a lot of HP running that rich in the lower load sites. You should be reaching your target AFR by peak torque but not at tip in. If you lean it out below 5K you will notice a difference. I tested this on a dyno recently and I was able to pick up 15HP and the response is much better. Even the factory runs ECU runs leaner in the lower RPM. Maybe Jack can elaborate a little.
