Building a DYI knock listener
It was starting off form the topic of "knock value" here https://www.evolutionm.net/forums/sh...d.php?t=154517
Then I spent an hour google'n and finally found an URL about it.
http://home.netcom.com/~bsundahl/kno...ten/listen.htm
I am not an electronic engineer, could someone please translate this information to simple English? I need to know the part list for the headphone type listner on the second diagram. Resistors listed here do not have a spec (other than 1/4 watt) ... and I suppose all C1, C2, C3 and C4 are all rated at 15V? I am a bit confused.
I would love to try to make one and test it out on the Evo, but I really need the part lists
Hope this helps. If you need any more info let me know
R= Resistor
C= Capacitor (All capacitors should be 16 Volt or Greater)
uF = Microfarad
R1 = 500K potentiometer AT
R2 = 27 Ohm 1/4 Watt 1% or 5%
R3 = 10 Ohm 1/4 Watt 1% or 5%
C1 = 0.1uF 16V Ceramic or Polyester
C2 = 470uf 16V Electrolytic or Tantalum (this is polarized)
C3 = 100 uF 16V Electrolytic or Tantalum (this is polarized)
C4 = 0.01uF 16V Ceramic or Polyester
U1 = LM380 Audio amp
R= Resistor
uF = Microfarad
kmcconn9,
I am already using something called Knocksense, which is an inexpensive tool widely used in the Volvo community. It basically read an voltage signal higher than a preset level, then it will light up the LED. The higher the voltage is, the brighter the LED. But it doesn't tell me exactly rather it is engine noise or knocks. I think KnockLink is basically the same thing, except that it uses multiple LED which makes it more useful. Thanks for your input, but I am really looking into something that I can listen to what's going on.
stuevo03,
Thank you so much! That is exactly what I am looking for! Now that is something I can understand
stuevo03,
philr8
Jan 15, 2011 07:32 PM
CactusJack
Jan 25, 2008 07:58 PM
