Will There ever be Speed Density?
I've had the Utec for about a month now, and after doing lots of research i found that there is more than enough work going to a blow thru meter, i was wondering if TurboXS will ever give the option for speed density
Well, at the least I hope they use some sort of blowthrough setup.. However if the coding is flexible enough, its possible to offer both.. I at least want them to make the MAF upgrade coding flexible enough to use any type of MAF (GM which is a frequency, or Ford which is analog voltage) and a AIT (air temp sensor) that can be calibrated.
I don't know whether speed density will ever be offered, its certainly capable of doing it. But most of us who were asked seemed to prefer something more "Dynamic" than speed density.
