PnP ???
PnP ???
Quick question on the PnP.
Does the PnP have the flatshifting and launch controle features like the SMC units do? On the Autronics site it states all the ECU's are based on the SMC family w/ stepper idle control, ignition coil dwell,and internal reluctor added.
Thanks for your help
Chris
Chris
Chris
Chris
yes but you have to set things up a little differently. for 2-step you use a relay and 100 ohm resistor that whn activated will sent a different coolant temp reading. you just insert higher values and adjust the RPM, fuel, timing etc at that offset value. everything the SMC has the PnP has.
http://www.autronic.com/page_files/techdata.htm
te 2-step and flat shift setup diagram can be found here.......
FS[MidWest]: Motec M800 PnP for Evo 9
Mitchubishievo
17
Nov 28, 2017 03:13 AM
FS[Mid-Atlantic]: ID 1000cc injectors+PnP 300$
MisterRegato
Nov 11, 2015 12:20 PM
casper980
18
Jun 8, 2009 09:39 AM
