Utec Maps??
Utec Maps??
I was wondering if anyone had close to the same mods as me and would share their maps for utec?I have no tuner around my area that is familiar with the UTEC.I just wanted to see if someone would share theirs with me for a base line.
My mods are:
Hks 264/272
fidanza cam gears set at -2
MBC 20psi
Injen intake & IC pipe
AMS Intercooler & lower IC pipe
Tubular header
O2 housing
Walbro 255 fuel pump
Apexi N1 downpipe
Cat delete
Greddy S BOV
TurboXS UTEC & Map switch
If someone could please help me I would appreciate it.Also I have did searches on here and haven't found anything.I would just like someone to share their maps & logs with me.
My mods are:
Hks 264/272
MBC 20psi
Tubular header
O2 housing
Apexi N1 downpipe
Cat delete
Greddy S BOV
I have made a pretty good timing map, for a car with and without cams. Ask Nez136 if he likes his tune I did for him. Although the fuel map is all on yourself, since with weather and altitude it makes a difference.
Now if you do decide to use my map, be forwarned if you damage your car it's not my fault.
Here are some logs of my everyday 93 octane map.
3239, -5.2, 530,100, 10, 00, 13.3, 19.7, +5.6,-11.3,ECU. , 316
3330, -1.5, 576,100, 10, 00, 12.3, 23.3, +5.4,-12.4,ECU. , 545
3450, +3.0, 761,100, 10, 00, 12.2, 28.7, +5.2,-13.5,ECU. , 514
3553, +7.2, 963,100, 10, 00, 12.1, 38.4, +5.1,-14.1,ECU. , 965
3720,+11.5,1138,100, 20, 00, 11.2, 48.5, +5.2,-16.9,ECU. ,1157
3858,+16.5,1057,100, 30, 00, 10.9, 48.4, +5.3,-19.8,ECU. , 778
3977,+21.1,1141,100, 30, 00, 11.4, 47.4, +5.8,-19.3,ECU. , 936
4171,+24.3,1162,100, 40, 00, 11.8, 47.7, +6.1,-22.0,ECU. , 965
4363,+25.6,1182,100, 40, 00, 12.0, 47.4, +6.7,-22.6,ECU. ,1091
4572,+25.8,1305,100, 40, 00, 12.0, 48.8, +7.3,-22.8,ECU. ,1068
4708,+25.8,1329,100, 50, 00, 11.7, 49.2, +7.3,-23.8,ECU. ,1000
4852,+25.4,1347,100, 50, 00, 11.8, 55.6, +7.4,-23.5,ECU. ,1082
5012,+25.2,1488,100, 50, 00, 11.7, 57.9, +7.5,-24.0,ECU. ,1225
5208,+25.2,1524,100, 60, 00, 11.6, 58.6, +7.7,-23.4,ECU. ,1213
5367,+25.0,1524,100, 60, 00, 11.4, 63.7, +8.6,-24.3,ECU. ,1068
5509,+25.0,1543,100, 60, 00, 11.3, 62.8, +9.6,-25.1,ECU. ,1201
5678,+24.7,1607,100, 70, 00, 11.3, 64.5,+10.1,-26.7,ECU. ,1237
5858,+24.3,1639,100, 70, 00, 11.4, 62.3,+11.4,-27.1,ECU. ,1136
5973,+24.3,1718,100, 70, 00, 11.3, 67.0,+13.2,-26.8,ECU. ,1344
6161,+24.1,1718,100, 70, 00, 11.1, 68.2,+14.9,-27.2,ECU. ,1231
6289,+24.1,1748,100, 80, 00, 11.0, 65.8,+16.0,-28.0,ECU. ,1315
6459,+23.9,1779,100, 80, 00, 11.2, 70.1,+16.8,-28.3,ECU. ,1351
6600,+23.9,1805,100, 80, 00, 11.2, 72.3,+18.5,-28.9,ECU. ,1282
2730, -6.2, 328,100, 10, 00, 11.7, 13.8,+10.0, -5.0,ECU. , 459
2815, -2.7, 380,100, 10, 00, 11.5, 13.9, +9.6, -5.3,ECU. , 353
2822, +1.2, 423,100, 10, 00, 11.4, 15.7, +9.3, -6.1,ECU. , 314
2871, +2.4, 460,100, 10, 00, 11.5, 17.7, +9.0, -6.8,ECU. , 347
2955, +3.6, 537,100, 10, 00, 11.3, 20.5, +7.9, -7.5,ECU. , 611
3046, +5.3, 580,100, 10, 00, 11.3, 22.3, +6.9, -8.8,ECU. , 541
3138, +6.7, 676,100, 10, 00, 11.7, 23.3, +6.1, -9.5,ECU. , 679
3284, +8.7, 776,100, 10, 00, 11.3, 31.1, +5.1,-10.9,ECU. , 710
3394,+10.8, 888,100, 10, 00, 11.1, 35.2, +5.0,-12.1,ECU. , 737
3534,+13.4,1048,100, 20, 00, 10.8, 42.0, +4.8,-13.7,ECU. , 741
3695,+16.7,1152,100, 30, 00, 10.8, 47.8, +4.9,-16.7,ECU. , 654
3853,+19.8,1113,100, 30, 00, 10.7, 44.9, +5.3,-19.0,ECU. , 776
3977,+22.6,1154,100, 40, 00, 11.0, 46.6, +5.7,-20.9,ECU. ,1041
4166,+24.4,1272,100, 40, 00, 11.4, 47.8, +6.1,-22.1,ECU. , 980
4368,+25.5,1219,100, 40, 00, 11.5, 49.1, +6.7,-22.5,ECU. ,1072
4504,+25.3,1385,100, 40, 00, 11.6, 48.4, +7.3,-22.8,ECU. , 996
4668,+25.1,1344,100, 50, 00, 11.7, 50.8, +7.3,-22.8,ECU. ,1131
4880,+24.9,1377,100, 50, 00, 11.6, 52.5, +7.4,-23.2,ECU. ,1162
5020,+24.2,1543,100, 50, 00, 11.5, 58.3, +7.5,-24.0,ECU. ,1126
5192,+24.2,1488,100, 60, 00, 11.3, 59.3, +7.7,-23.4,ECU. ,1250
5341,+24.2,1644,100, 60, 00, 11.3, 60.2, +8.4,-24.1,ECU. ,1282
5546,+23.8,1628,100, 60, 00, 11.1, 58.3, +9.6,-25.1,ECU. ,1146
5698,+23.8,1650,100, 70, 00, 11.3, 65.1,+10.2,-26.9,ECU. ,1336
5889,+23.6,1742,100, 70, 00, 11.3, 67.7,+12.0,-27.0,ECU. ,1237
6027,+23.4,1779,100, 70, 00, 11.2, 66.3,+13.8,-27.0,ECU. ,1173
6172,+23.2,1792,100, 70, 00, 11.1, 65.9,+15.2,-27.5,ECU. ,1366
6361,+23.2,1811,100, 70, 00, 11.1, 69.6,+16.3,-27.8,ECU. ,1336
6510,+23.0,1845,100, 80, 00, 11.0, 68.0,+17.1,-28.5,ECU. ,1373
6693,+23.0,1851,100, 80, 00, 11.1, 69.6,+19.1,-29.1,ECU. ,1366
6788,+22.8,1886,100, 80, 00, 11.2, 69.8,+20.6,-29.5,ECU. ,1315
6944,+22.0,1923,100, 80, 00, 11.1, 69.8,+21.3,-29.2,ECU. ,1436
7092,+22.0,1901,100, 80, 00, 10.6, 73.1,+21.9,-29.2,ECU. ,1396
7246,+21.8,1908,100, 80, 00, 10.7, 72.3,+22.3,-28.7,ECU. ,1453
7342,+21.8,1923,100, 80, 00, 10.7, 73.3,+22.4,-29.0,ECU. ,1461
7490,+22.0,1968,100, 80, 00, 10.6, 75.9,+22.4,-28.6,ECU. ,1436
If you notice on the 2nd log I am running quite rich from 2700-4000, this is causing the turbo to spool a little slow. And if I remember correctly my MAP sensor was on FUBAR mode so the boost column please look over.
450 hp /383tq map
A map by itself won't do you a lot of good without a very detailed list of mods and some fine tuning...it's like building your own pc...every set-up is different so one-size does not necessarily fit all
Vivid Racing
13
May 27, 2007 02:45 PM
SubiEvolved
21
Sep 17, 2004 08:05 AM
