View Poll Results: Alky/Meth option
Yes
17
100.00%
No
0%
Voters: 17. You may not vote on this poll
Alky/Meth Option for ECU+
I really don't think anyone is going to reply with "no". Espically since its a software mod and not a hardware.
I plan to use alky as a means to ring out every last ounce of power from my setup but that is going to be the last mod I put on the car... after everything else is completed then and only then will I turn up the boost and use alky. So do I think its a worth while addition, yes.
Man this stuff just keeps getting better and better .
Are there any plans to add no lift shifting and launch control?
I already have and running the SMC injection kit (pure Methanol) with the controller box that came iwth it. If Tom can make the ECUplus control it it would be icing on the cake for me. Taht would save me at least half a pound of weight! :P
Go TOm GO! Let me know if you need a tester. hehe
As I posted in the other thread ALKY/METH compatibility is great, but to make it specific to one brand of system would be very limiting. Not everyone runs the same kit. I know of a few people that run the SMC, some folks run the cooling mist etc etc etc. Handcuffing the folks who dont run one specific brand seems counter productive.
Just my 1.896 cents
Just my 1.896 cents
Just my 1.896 cents
Just my 1.896 cents
Tom
I just sold my Eclipse, but I used the Aquamist FIA2/HSV for the meth/water injection control. What this does is mirror the inecjtor pulses and pulses the high speed solenoid the same way, so that you have a constant fuel to injection ratio.
Is there a way for you to write some code that will enable one of the outputs of the ECU+ to mirror the injector firing of one cylinder? That would be very nice as then people could simply buy the HSV from Aquamist and have a true progressive system.
Eric
P.S. Also, the way DSMLink lets you control WI is to use the line from the FPR solenoid. You can control that line via parameters like RPM, knock, etc.
Eric
Tom
Originally Posted by tlcoll1
That'd be pretty simple, code-wise. Is it just signals levels (and the desire to not mess up the signal) that keeps you from using the injector signals directly?
Tom
Tom
I'm guessing that your assumption is correct, but Aquamist has a whole separate controller called the FIA2 which uses the injector signal as an input and then drives the HSV. So, I would assume it's a signaling issue, but I have never looked into is, so don't quote me on anything.
Eric
kreionic
624
Nov 29, 2011 05:04 PM
dryad001
Oct 14, 2005 06:54 PM
