Utec tuner lite wiring diagram??
Sup guy's
i bought a used utec and tuner lite unit from Mr stock and everything looks good plug the utec and starts right away . but im having problem with the tuner box as it does'nt have any wiring diagram for it . does anyone knows which wire goes to battery and ground? any help would be great. btw i've used the search and nothing came up and check the tuner manual and also nothing
Thanks
Herb
Thanks
Herb
Oh yeah.. Red is the positive (power) white or black is the ground.. There should be three "Groups" of wires on the tuner pro, two groups on the Tuner Lite.. The thick one is the O2 sensor, the thinnest is the power feed, and the middle sized one is the Knock sensor (on the pro)
Thanks MalibuJack
got everything working now thanks for the info . one more question i took of the factory 02 sensor right after the cat and use the wideband sensor is it ok to do that ? of do i need to weld on another bung?
In other words, you probably should put a new bung in for the sensor.. It should be before the Catalytic converter, some people say to put it as close to the turbo outlet as possible, others say to put it towards the rear of the downpipe before the catalytic converter.. I say, whichever location you can find to fit it..
mfr122887
13
Apr 16, 2008 04:08 PM
Vivid Racing
13
May 27, 2007 02:45 PM
201Motorsports
12
Sep 30, 2006 09:09 AM
