Evo IX ECU Question
Old Oct 31, 2005 | 02:49 PM
Kronik's Avatar
Evo IX ECU Question
Can anyone confirm or deny that the Evo IX ECU has the same connections as the Evo VIII? I'm asking this question since I have a ECU+ and I have heard that the plug-n-play harness will not work with the IX...
Old Oct 31, 2005 | 03:00 PM
inco9nito99's Avatar
I'm curious as well...also, what if any are the differences in the programming between the two? Minus the fact that one is for the MIVEC Cam timing and one, not.
Old Oct 31, 2005 | 03:39 PM
SR20DE-T's Avatar
Yes the EVO IX and the EVO VIII ECU harness is different. The EVO IX has 3 plugs vs 4 for the EVO VIII.
Old Oct 31, 2005 | 04:59 PM
DynoFlash's Avatar
correct - all the pin outs have changed 100%
Old Nov 2, 2005 | 12:11 AM
amg_dragon's Avatar
Does anyone have a pinout diagram of the EVO IX's ecu yet? Is it anything like the pinout for the Ralliart (4G69 w/ MIVEC)? It's been speculated about for almost a year buy us step children but with the IX stateside someone should have an answer right? Please let us know if you're lucky enough to have a IX!
Thanks in advance guys.
Old Nov 14, 2005 | 04:02 PM
SmokinJoe's Avatar
I'm also looking for the wiring diagram for the IX - Going to hold off on installing the SAFC2 till we can locate a diagram
Old Nov 22, 2005 | 02:43 PM
kitw's Avatar
Bump for this, anyone find the pinout yet?
Old Nov 22, 2005 | 02:51 PM
coco's Avatar
I too was looking for the diagram of the ECU cause I wanted to connect my turbo timer to the speed sensor.
Pete @ Works helped me so now my turbo timer is fully functional sans the parking brake safety. I set my timer to beep whenever I go faster then 80 so it will remind me to slow down. Cool feature!
The US evo 9 ecu is similar to the UK one but there are slight differences.
Old Nov 22, 2005 | 06:23 PM
SmokinJoe's Avatar
I thought I had a contact to post or fax the ECU pins but it hasnt panned out yet. I'm still looking. Does anyone have this info defined elsewhere?
Old Dec 16, 2005 | 12:25 PM
kitw's Avatar
Bump for this thread... Surely someone has to have ecu pinout information!
Old Dec 21, 2005 | 06:21 PM
andenbre's Avatar
here they are for the europian 9 so confirm wire colors and pin positions before splicing
Attached Thumbnails Evo IX ECU Question-9ecu1.jpg   Evo IX ECU Question-9ecu2.jpg   Evo IX ECU Question-9ecu3.jpg   Evo IX ECU Question-9ecu4.jpg   Evo IX ECU Question-9ecu5.jpg
Old Dec 21, 2005 | 06:23 PM
andenbre's Avatar
Attached Thumbnails Evo IX ECU Question-9ecu6.jpg   Evo IX ECU Question-9ecu7.jpg   Evo IX ECU Question-9ecu8.jpg   Evo IX ECU Question-9ecu9.jpg
Old Dec 21, 2005 | 07:17 PM
SmokinJoe's Avatar
This is great! Can anyone decifer and circle the pins needed for the Apexi SAFC?
Thank you a 100 times!
Old Dec 27, 2005 | 01:19 PM
peru evo's Avatar
Pinout IX
Hi all
Hope this helps you out!!
have a nice new year and a good 2006 racing year
File Type: pdf
Old Jan 5, 2006 | 10:24 PM
silex's Avatar
Thank you a million times over! You have made me a happy man! It's late to say this, but Happy New Year to you too!
Was that pdf and those pics from a service manual of some sort? Whatever book it's from, I'd like to get a copy of it! Inquiring minds need to know.
Quick Reply: Evo IX ECU Question
