SafcII...want to boost higher. do i need bigger injectors
Im about to install the safc II and want to tune at 25 psi boost. Would i need to get bigger injectors (720cc) in order to safely boost 25 when i take it to get tuned or would the stock injectors with the 255 walbro fuel pump be fine?
Stock injectors with Walbro will be fine for running 25psi. The S-AFC portion of that is not relevant, but I would certainly not recommend using an S-AFC as your tuning advice if you're going to rely on someone else to tune it. The S-AFC is for tuning yourself and is mainly for low power applications, since it can't control timing. A flash or more advanced piggyback will give you a far better tune, especially since you're talking about running full-time on meth or race gas (re: 25psi). Please reconsider if you still can...
I plan to get alochol injection in spring. But for now im running a dual stage boost controller (so its not going to be running full time on 25psi) so i want to tune on my high boost (25psi) with the walbro and the safc. (its going to be tuned by a shop). What do you think about getting a flash, then tuning the safc on top of that? Also, what can i buy to control the timing and tie it in with the safc tuning? thanks
I now run my S-AFC on top of a base flash. I think that works great, because your timing is already set by the flash for the mid-range (can't do this with s-afc), but you are able to fine-tune with the S-AFC, especially when at the track and using race gas.
There's nothing for your last question. If you want to control timing, which you should want to do, then you don't get an S-AFC. The S-AFC is for basic tuning with basic mods.
The thing is i already have an safc from my previous car and i dont think i should just leave it to waste. Also, i didnt plan on slapping on the alky kit and thinking it would work, i was planning on tuning on high boost then when adding the alky kit, re-tune, but now i know i cant run 25 psi without the alky kit, thanks. So i should just wait until i get the alky kit in order to get the flash/run higher boost, then use the safc to fine tune ontop of that flash? Also, would i need bigger injectors to support the 25psi/alky injec. or would the stock injec. work fine with the walbro fuel pump? Thanks
I already answered that in my first response:
Yes, I suggest getting the alky and a flash for all of your mods, then install the S-AFC and use it to fine-tune. Be sure you have a wideband O2 for accurate AFR readings, and a logging device to watch your timing.
Originally Posted by mchuang
If you have a pretty conservative base flash with afc..at like 21psi..and still using stock ecu..wont the ecu yank timing if the knock sensor voltage gets in the range where knock is about to occur
Yes, if the ECU detects knock, it will retard timing, but what is your real question? That didn't really have anything to do with a flash or S-AFC...it's just a basic ECU function.
Nobody has said anything about the fact that boost level doesn't determine fueling requirements alone.
25 psi on stock cams is not the same as 25 psi on 272s
25 psi on stock exhaust is not the same as 25 psi on a catless turboback
and while I think you're assuming this is on the stock turbo...
25 psi on the stock turbo is not 25 psi on another turbo
Airflow is the key. You need fuel to match the airflow you're pushing in the ratio you want (air/fuel ratio). As an example...If you have big cams you're going to max the stock injectors a couple pounds of boost lower than a car without them on an otherwise identical setup at the same air/fuel ratio. Head work, oversized valves, and other mods that aid in airflow all require extra fueling.
Watch your injector duty cycles, wideband, knock, and EGT readings.
-Mike
-Mike
Thanks for the info warrtalon and mike. i was also wondering... lets say i get the alky kit, boost 25 (on the dual stage boost controller), stock turbo/cams, tbe, ss manifold, turbosmart bov, intake, 255 fuel pump.. and i get a tune on 25 (high) psi/alky kit, then i fine tune with the safc after that. wat would happen if i switch back to stock psi on my low setting on the boost controller for daily driving? will it drive fine so when i just want to turn up the boost/turn on the alky injec. itll work fine?
Like he said, get a map tuned for each setting. It can hold two.
Lowering the boost and turning off the alcohol injection while running your high boost + alky injection tune could actually make the car run lean and detonate.
-Mike
-Mike
Alrite thanks. So u just switch between the 2 maps inside the safc then huh. See , I wanted to do the 2 maps because i use the car as a daily driver so i dont want to be constantly pushing 25psi and wearing down the engine. But thanks for the info, it helped alot.
-Mike
