Air Temp Sensor
Air Temp Sensor
Is it possible to use a smaller air temp sensor with the MAFTpro? If not, what is the most ideal way to mount it so it is not causing an obstruction to the airflow? On a car with 2 inch stock piping the GM sensor just seems huge to put in there, especially if you thread it all the way in. Any feedback is greatly appriciated.Thanks in advance.
Pete
Pete
I researched getting some made, I gave up when I found out how much they were going to cost.......
If you locate an OEM sensor that looks like it will work we can see if it can be added as an option in the pro.
Bob
Bob
