Boost control
Boost control
Im finally getting around to hooking up the boost control and since the wiring isn't long enough to where I want to put the solonoid. What is the max length of the pressure hoses? Or I was thinking of getting a new molex connector and make the wires longer. Any input would be great, or let me know what spot you used to mount the solonoid. Not much mounting room under there.
I ran my wires through the front right fender and then across just above the radiator. They were just long enough for me to get the solenoid to the other side of the radiator. I mounted the solenoid behind the driver's side headlight. It would be nice if the wires were a bit longer, as I only have about 1 foot of slack in the glove box.
-Paul
-Paul
Well I ended up taking out the battery tray and everything else around there. I ran the wires under the tray up to the firewall and right under the strut bar, can barly notice it's even there. I might as well get the BR alky kit in there while eveything is apart.
05-EVO-GSR
Feb 23, 2017 11:57 AM
Appauldd
May 4, 2004 05:08 PM
