Base map for MAP?
Base map for MAP?
I think i might ponder a switch here, after the weekend track day and switch over to MAP reference, but i know all my fuel and timing tables are gonna be whack. correct?
So is there a base reference map to start off when converting?
thanks
thanks
I second that... Its important to check your tune on days where the weather changes severely (Air pressure changes) since those could affect boost levels and could also affect the density of the air where a tune in a particular column will change.
This MAP reference is not a speed density reference, so your only using boost pressure for your map... Don't cut too deeply to the bone on your tunes since a cold day where the air is alot more dense could leave you running a bit leaner than you expect.
i'm in florida, we don't get cold days down here for about 10 months of the year, if it drops below 70-65, thats front page news
I'll keep it in mind though, i have a boost gauge, and a manual controller to fix that
I have found i'm still running a good amount of timing over what i'm calling for though, but not nearly as much as before.
I did another pull and it dropped about that .1 in af. Have a slight o2 housing exhaust leak also, so thats not helping, just makin it a touch leaner than it really is.
Code:
4775, +5.3,1282,100, 30, 00, 10.0, +10.8, 49.4, +9.5, -5.7,ECU. , 965 4909, +6.3,1408,100, 40, 00, 10.3, +9.8, 51.7, +8.1, -5.5,ECU. ,1008 4990, +8.9,1333,100, 60, 00, 11.8, +10.9, 49.3, +6.6, -7.0,ECU. , 939 5081,+12.8,1351,100, 70, 00, 11.7, +11.2, 50.6, +6.4, -7.0,ECU. , 862 5159,+16.4,1412,100, 80, 00, 11.4, +11.0, 51.2, +6.5, -7.0,ECU. ,1004 5257,+19.3,1392,100, 90, 00, 11.5, +12.3, 51.0, +6.8, -7.0,ECU. , 899 5341,+21.0,1432,100, 90, 00, 11.5, +12.2, 52.6, +6.8, -7.0,ECU. ,1275 5437,+21.8,1440,100, 90, 00, 11.5, +12.1, 53.4, +6.8, -7.0,ECU. ,1152 5546,+22.0,1488,100, 90, 00, 11.5, +12.3, 54.2, +7.0, -7.0,ECU. , 950 5621,+22.0,1547,100, 90, 00, 11.5, +13.3, 55.0, +7.3, -7.0,ECU. ,1106 5707,+22.0,1515,100, 90, 00, 11.4, +13.4, 55.9, +7.8, -7.0,ECU. , 922 5787,+22.0,1572,100, 90, 00, 11.6, +15.5, 55.6, +8.3, -7.0,ECU. ,1136 5899,+22.0,1562,100, 90, 00, 11.7, +15.6, 56.8, +8.6, -7.0,ECU. ,1101 5952,+22.0,1519,100, 90, 00, 11.5, +16.4, 56.6, +8.9, -7.0,ECU. ,1162 6038,+22.0,1515,100, 90, 00, 11.5, +16.4, 57.2, +9.3, -7.0,ECU. ,1168 6127,+21.8,1597,100, 90, 00, 11.4, +17.4, 58.9, +9.4, -7.0,ECU. ,1101 6218,+21.8,1618,100, 90, 00, 11.6, +18.3, 59.7, +9.6, -7.0,ECU. ,1111 6265,+21.5,1639,100, 90, 00, 11.6, +18.3, 60.3, +9.8, -7.0,ECU. ,1111 6337,+21.5,1639,100, 90, 00, 11.4, +19.4, 61.4,+10.0, -7.0,ECU. ,1219 6422,+21.5,1655,100, 90, 00, 11.5, +20.7, 61.7,+10.4, -7.0,ECU. ,1225 6485,+21.8,1689,100, 90, 00, 11.4, +21.6, 62.5,+10.8, -7.0,ECU. ,1237 6548,+21.8,1700,100, 90, 00, 11.3, +21.7, 62.5,+11.1, -7.0,ECU. ,1201 6640,+21.8,1700,100, 90, 00, 11.4, +22.4, 63.6,+11.4, -7.0,ECU. ,1131 6706,+21.8,1718,100, 90, 00, 11.5, +23.4, 63.8,+11.7, -7.0,ECU. ,1213 6747,+21.8,1700,100, 90, 00, 11.5, +23.6, 63.4,+11.9, -7.0,ECU. ,1225 6816,+21.5,1644,100, 90, 00, 11.6, +24.5, 63.7,+12.1, -6.9,ECU. ,1157 6872,+21.5,1694,100, 90, 00, 11.4, +24.7, 64.9,+12.6, -6.7,ECU. ,1196 6958,+21.5,1677,100, 90, 00, 11.6, +25.8, 63.5,+12.7, -6.7,ECU. ,1168 7002,+21.5,1718,100, 90, 00, 11.5, +25.7, 63.9,+13.1, -6.5,ECU. ,1179 7047,+21.5,1730,100, 90, 00, 11.5, +25.7, 64.4,+13.2, -6.5,ECU. ,1162 7122,+21.5,1689,100, 90, 00, 11.5, +25.8, 64.5,+13.7, -6.5,ECU. ,1219 7168,+21.5,1742,100, 90, 00, 11.5, +26.9, 64.4,+14.2, -6.5,ECU. ,1207 7215,+21.3,1724,100, 90, 00, 11.5, +26.8, 63.9,+14.5, -6.5,ECU. ,1152 7278,+21.3,1694,100, 90, 00, 11.6, +26.7, 65.0,+14.8, -6.6,ECU. ,1201 7309,+21.5,1754,100, 90, 00, 11.5, +26.9, 65.1,+15.2, -6.9,ECU. ,1269 7374,+21.5,1718,100, 90, 00, 11.4, +26.9, 64.7,+15.7, -6.9,ECU. ,1243 7440,+21.5,1730,100, 90, 00, 11.5, +26.9, 64.6,+15.7, -7.2,ECU. ,1219 7490,+21.8,1706,100, 90, 00, 11.5, +28.0, 65.0,+16.2, -7.5,ECU. ,1168 7507,+21.5,1742,100, 90, 00, 11.4, +28.0, 64.7,+16.4, -7.5,ECU. ,1131 7558,+21.5,1748,100, 90, 00, 11.5, +27.7, 65.9,+16.5, -7.5,ECU. ,1231 7627,+21.5,1754,100, 90, 00, 11.5, +27.9, 65.4,+16.6, -7.5,ECU. ,1225 7662,+21.5,1760,100, 90, 00, 11.6, +28.0, 65.0,+16.8, -7.5,ECU. ,1207 7698,+21.5,1718,100, 90, 00, 11.5, +29.0, 64.8,+17.1, -7.5,ECU. ,1162 7770,+21.8,1712,100, 90, 00, 11.6, +28.9, 64.6,+17.1, -7.5,ECU. ,1295 7806,+21.5,1730,100, 90, 00, 11.5, +28.9, 65.1,+17.3, -7.5,ECU. ,1179
ICE888
18
Jul 13, 2005 07:57 PM
