Pigtails for GM solenoid and 3 bar MAP Sensor
I am looking for a clean install of these..where can I find pigtails for these connectors? Would radio shack sell them (doubt it). Also, where are you mounting your MAP sensor at?
I used the Buschur adaptor plate and installed it in the stock MAP location. In fact, I would contact BR to find out about the pigtails too. Of course I run the AEM unit...so I dont know if that will make a difference for you with the UTEC
Ok confusion...as usual. If I understand correctly you can run a map sensor without switching to MAP as a your load indicator. It would just be there for reference and too use for a closed boost monitoring system. Right????
But some people are using MAP also as their load indicator From what I have read the jury is still out on whether MAF or MAP is better for the load indication...right?
I am only interested in the MAP sensor for boost level feedback and closed boost control at this time. So I guess I should say, where are you putting your map sensor if you are not replacing the MAF sensor. Does this make any sense or am I totally confused again.
Be careful how you loop stuff in, anything that works on the bleed principal, will reduce the signal available to the DV... Same with any restrictions from using T's.. I generally recommend using something other than the DV line unless you are real careful to use very short runs of hose, and large diameter T's that won't restrict the signal to the DV.
malibu,
i tend to agree...
we currently use the vacuum output nipple on the intake mani near the tbody to supply the signal to the map sensor and bov.... with braided stainless lines to both.
the mbc gets its signal from a tapped fitting on the lower intercooler pipe, and then go the the controller and to the wastegate. shortly....we will be re-doing it.... using a perrin EBCS (with the utec) with braided lines... utilizing both wastegate ports..
when we reduced the number of t's from that nipple, we saw added response in the tial bov and mbc.
my two cents
cb..
im producing some vacuum blocks for sale.. with our logo cnc'd on them.
i tend to agree...
my two cents
cb..
Originally Posted by CBRD
malibu,
i tend to agree...
my two cents
cb..
i tend to agree...
my two cents
cb..
