Blowing fuse...
Old May 9, 2006 | 10:03 PM
Ultimate CC's Avatar
Blowing fuse...
Does anyone else get the problem of blowing the 10 amp engine fuse when you save a map every once in a while. I am thinking this has something to do with the ground on the UTEC.
Old May 9, 2006 | 10:07 PM
Nez136's Avatar
very strange, i haven't had the problem nor heard of anything of the sort happening, is there anything else hooked up with the Utec besides the tuner?
Old May 10, 2006 | 05:21 AM
MalibuJack's Avatar
I have never heard of a blown fuse.. Occasionally if you have a few things hooked up to the ECU power you will blow the fuse, but just the UTEC shouldn't cause it..
Old May 10, 2006 | 05:28 AM
dryad001's Avatar
Yeah thats odd. Where are your gauges tapped into (for the lights)?
Old May 10, 2006 | 06:48 AM
The only thing I have hooked up to the fuses is the map selector and thats on a different fuse, everything else in my car has a direct power source with the battery...
Old May 10, 2006 | 06:52 AM
MalibuJack's Avatar
the map selector doesn't have any power requirement.. That connector is shared with the shift lights so I'm assuming you mean either that or the solenoid/relay output.. Which requires a relay because anything that draws more than a few mA of current will blow your fuse.
Old May 10, 2006 | 07:07 AM
I will have to look at it again today, maybe thats my turbo timer but I will have to see...
bml1024
Feb 6, 2017 11:34 AM
Headhunterz1105
Aug 9, 2016 03:01 PM
AlexC330NY
Lancer Troubleshooting
Mar 29, 2016 08:36 AM
neurotic ramble
13
May 2, 2011 08:38 AM
OtownEvo
15
Jun 9, 2007 06:54 PM
Quick Reply: Blowing fuse...
