Should i go ECU flash or SAFC controller?
been doing a bunch of research, and i came to the conclusion that i cannot come to a decision on what route to go. Ive heard its easy to just get an ECU flashed based on what mods you have and its fairily accurate, but at the same time ive been told by a few local tuners to skip the flash purchase a safc controller and just get it custom tuned and as i purchase more performance parts just have re adjusted rather than getting reflash after reflash
Opinions or comments more than welcomed thanks!
BTW, if your curious, im not planning on doing big turbo within the next year i dont suppose, but i would like to get TBE,02 housing,exhaust mani,maybe cams when they are available,intake, and a few other bolt ons... for those who are trying to figure out what would be the best route for me! thanks in advance
IMO your best bet would to call Buschur Racing and order the Warrtalon package,you,ll have a very quick,excellent running car,reliable as stock(if not more)and you,ll have your flash.the power you will be making will keep you more than happy untill you plan on upgrading your turbo,good luck,Danny
no need for the safc when u get the flash that will change your fuel maps. but if u have like add ons such as intake, bov, stuff like that safc will fine tune that stuff but i would go with a flash
I am currently just using a SAFCII to tune with and it's been working great, I made 310WHP 312Ft-lb with a tb(w/ high flow cat), intake, IC pipes, and mbc set to 21 lbs. I like being able to just go retune after new mods, but I have also heard of people getting base flashes then using a AFC to fine tune with after mods.
Nick, that was with a ridiculous SAE correction, so you can't use those numbers for comparison. If I used my corrected numbers for Denver, I'd be claiming 380whp/425wtq, which are nowhere near reality. My uncorrected numbers are 300whp/337wtq, and I know you're nowhere near my power level.
It's not to be able to retune for mods, but the SAFC has no control over timing, so you aren't making near as much power as you would with a flash, and you have none of the flash features. Additionally, it's very difficult, strange, and rare to have more torque than HP with an SAFC on 91oct without upgraded injectors. I'd have to see your dynographs, AFRs, and timing to believe it.
War.... I know that my numbers are corrected, I never said they were uncorrected but I tuned at Carz Custom and my car has been sort of a freak because it made more power on the same dyno than Carz 9 when we had the same mods( it wasn't much like maybe 6-7 whp).
I am currently looking into other EMS so that I can control more than just air-fuel.
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
631
Sep 27, 2010 05:19 PM
SpeedI2acerX
Jul 6, 2008 01:53 AM
maxum17ft
Lancer Engine Management / Tuning Forums
23
Aug 13, 2006 12:23 AM
surfocean
Dec 26, 2004 02:26 PM
