Coil-on-plug
Coil-on-plug
Hi, I have a problem with a Nology Coil-on-plug and module system installed on an EVO7 with a MOTEC M800 ECU
the Nology ignition module has only 5 volts output and all Mitsubishi´s need a higher voltage module
Where can I find a good and not expensive ignition module that can solve this problem? Tks
What signal are you expecting? The ignition module itself is triggered by a 5v square wave, In fact their 2 channel ignition module looks exactly like a 1G DSM Module.. I'm assuming you adapted one of the COP systems and added the module for triggering? It should work fine.. I don't know what you mean by an output signal, but you could use an MSD Tach adapter to condition the signal for a 12 volt trigger if your talking about the tach output..
what I´ve done is replace OEM ignition module & cable wires.
Bought 04 Nology COP and 02 Nology Ignition modules
Installed them 02 COP per Ignition module
Nology ignition modules have a 5 volts square-wave
Maybe that is why engine starts but does not run well,even in minimum.
Are Mitubishi´s IM square-wave higher?. Or I have to tune something in the Motec M800 ECU.
Tks
Tks
How to Improve ignition coil on Original EVO 7?
hello..my name is yusof.
im new in evolutionm.Hope senior and super senior will teach me,
do you have any suggestion to improve the ignition coil on original evo 7?
can CDI intall in original ECU?
FS[Mid-Atlantic]: COP, never been used
LaFuriaRoja01
Feb 23, 2015 09:55 PM
PVD04
Sep 12, 2005 10:34 AM
