Got the EVO on the Dyno finally
We were just using a basemap and a new Timing map I wrote for it. We kept blowing the upper pipe off so we only got a few clean runs. This was done on Pump 100 octane from a local gas station which I hear its only near 94 octane. This is a built 2.0, PnP head, T3/T04R BB, 272s, 1600cc injectors, Power FC DJ with Datalogit and 26 psi. Timing is pretty damn conservitive, we ony showing about 4-5 counts of knock throughout the powerband. On top of that A/F were still 10.9-11.3 so it could use quite a bit of tweeking. All I have to say is Power FC is about the easiest damn EMS Ive worked with and runs damn near perfect with little work.
http://www.trevtec.com/Trevstuff/jamesdyno.jpg
538whp and 382 ft lbs, the best run we had is 546whp and 390 ft lbs but I only have the spec sheet on that dyno.
