CEL code reading w/ Tactrix cable ?
Anyone know of a software that can read CEL codes with Tactrix cable ?
Or is it simply not possible ?
The feature in Evoscan isnt working
btw saw similar threads posted before but didnt see any answer if anything is available or not.
kind regards
Gudmundur
kind regards
Gudmundur
There is a button in the bottom right of the application "Check DTC" which stands for Diagnostic Trouble Codes. I've never had an SES light to test this, but if the functionality actually works in EvoScan, that's how you'd get to it.
i found it with scantech thanks alot guys. Just to close up the thread, the evoscan CEL tool doesn't work with USDM evos. as staged by mailbujack. Download Scantech and use it under Jeff protocal with the right port, and it works.
supak111
Mar 16, 2016 12:17 AM
turboback1243
Sep 28, 2013 08:47 PM
