Dynoflash FKED YOUR OEM ECU?
Old Sep 28, 2006 | 10:16 AM
evoLuzN's Avatar
I wonder if I do Al(Dynoflash) and it will cause problem for your original mitsu ecu. Last week I was driving in NYC and all the sudden my car locked up. Call up tow truck and now my car sitting in mechanic garage. Guy call me up saying my ecu locked up everything and it might be burned. Any suggestion?
Old Sep 28, 2006 | 09:47 PM
troe666's Avatar
suggestion? get a better mechanic who can give you an accurate description of what has happened.
There's no way he can tell after the car is stalled etc that the ECU 'locked up everything' and unless he has the ECU Cable and software how is he even able to tell that the ECU has an issue?
additionally why is this in the ECUTek forum anyway?
Trav
Old Sep 28, 2006 | 11:23 PM
f-dub's Avatar
Are you sure you just didn't pop off a IC hose or something? Did your car throw a CEL? What code did it show? Your mechanic should be able to tell you this.
Old Sep 28, 2006 | 11:27 PM
scott yo's Avatar
can you elaborate a little more on what happened?
Old Sep 28, 2006 | 11:31 PM
Sharkbite2000's Avatar
Hmmmm, anything else with story ?
Old Sep 29, 2006 | 04:11 AM
smoothmarine187's Avatar
Veteran: Marine Corp
I don't think I would be so quick to blame what happened on Al. At this point it doesn't sound like you have a clue what is going on with your car.
Old Sep 29, 2006 | 09:13 PM
hopper's Avatar
It sounds like Cletus told you your doohickey locked up and it wont turn on your electric carburetor. all al does is reprogram, he doesnt do any soldering or anything
Old Sep 30, 2006 | 09:21 PM
evo8dad's Avatar
Old Oct 12, 2006 | 04:01 PM
usarare's Avatar
Flux capsidor went bad? Give us some more info!
Old Oct 12, 2006 | 04:09 PM
boostingevo8's Avatar
Did the mechanic tell you he was not able to read your ECU?
Old Oct 12, 2006 | 04:12 PM
evo ippo's Avatar
maybe wut ur mechanic ment was that your ecu is locked, some tuners do that to protect there tunes or just to prevent people to access it and tamper with their tune even somtimes the dealer cant get to it go on the ecuflash section and read more about it. and the term locked up can mean so many things do elaborate
Old Oct 12, 2006 | 04:15 PM
Al probaly changed your immobolizer code to protect his maps. You will probaly have to send your ECU to Al to have it fixed. Umm mine was locked but a brilliant tuner was able to fix the problem and retuned my car and now it's running great.
PM Al directly and let him know your situation. I can tell you from experience he'd rather talk to you in person than read " Diluted information" posted on EvoM.
Good Luck however.
Old Oct 13, 2006 | 09:59 PM
evoLuzN's Avatar
Got it fixed. I towed back from NYC and got it fixed in Turbotrix. They tuned my car and Mark found that my ignition got bad and replaced a new one. Not only that, he transfered my flash from my ECU to my new one. (replaced new ecu) . I spent about $1g overall. fk it i aint messing with my car anymore.
PS: Im not sure is turbotrix fked it up or my ECU or ignition got bad.
Old Oct 13, 2006 | 10:13 PM
DynoFlash's Avatar
Sorry to hear you had a problem
Was this Dyno Flash with a ecutek ?
I have never seen anyone who's cars were running after a reflash fry an ecu - this is out of thousands of cars
I HAVE however seen some coils go bad
AL
kapolani
Mar 26, 2011 11:22 PM
DynoFlash
24
Apr 13, 2009 11:44 AM
StlEvo05
Oct 28, 2007 06:24 PM
MitsuEvoIIX
Sep 24, 2005 12:08 AM
