Help - MAF Honey Comb Finished... What now?
I previously had a 35r with a flash and just swapped in a 37r. Needless to say, the stock MAF honeycomb did not like this very much and was sucked out.
I want to stay flashed so I need a new MAF sensor. I was told to purchase a GM sensor. I did, but it turned out to be a 3.5" not a 3". Can I use the 3.5'? If not, what model vehicle does the 3" come stock on?
What else do I need to complete the MAF conversion.
Please help!
Thank In Advance
Please help!
Thank In Advance
Here is a current thread on the GM MAF translation
https://www.evolutionm.net/forums/sh...8&page=1&pp=15
Alright, the difference from the 3" to the 3.5" GM MAF is that the 3" is the older style that was used on a huge number of cars from 90-00. This has a 3-prong connector which most translators use. Now if you get the 3.5" GM MAF I believe it has a 5-prong conntector and a different sensor to measure airflow.
Malibujack is using a 3" MAF modified with 3.5" ends. I am using just the regular 3".
Ahh I see... Now I understand. I going to return the 3.5" tomorrow and get a 3".
Thanks!
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
sparky
Mar 18, 2013 08:36 AM
