SAFC II question before purchase...
Whats up evolutionm.net, I am new to the site and would like to know what are the good and bad benefits of having a sacf II? im not really looking to get a flash because the car is daily driven so i cant send the ecu out and get it flashed. What I am looking for is the following a simple street tune. Nothing to crazy if i do get a safc II what else would I need to buy? Boost controller, Turbo Timer etc.. I already have a Intake and blow off valve.... Let me know your opinion's thank you...
Originally Posted by thisxguy
intake and bov...the two things not needed for an evo. well, safc allows you to fine tune your air/fuel. it is an excellent tool for tuners. you can run 2 different maps.
cons...dealership will know you messed with the cpu and can void your warranty
I'm was already planning on putting the intake and bov back on...But im going to buy it and if i dont like what i get out of it then i will have to ge a flash like it or not...Thanks on the help
yeah
http://www.lancershop.com/customer/p...&cat=44&page=1
If you don't have a warranty, and don't mind doing the work yourself, and have access to a soldering iron, then here's how you hardwire it in........the SAFC itself should have came with directions & diagram....
http://www.lancerevotuners.com/forum...read.php?p=909
the great thing about the safc-2 is that its cheap and u can run 2 maps. I use one map for 93 octane gas and another for 110 i'm not sure if a flash can have 2 maps that switch back and forth. For basic tuning the safc-2 is the way to go, or the neo if you want a color screen, but unless you have enough money for an AEM or an Autronic unit i would say to give the safc a try. Get a wideband too that way you will know what to do with your safc.
Thats funny though the afc-2 can save 2 maps....i have a pad of paper and a pen in my glove box...thats my second map lol.
Hey i got one like new black edition for sell with the harness only 300.00 shippe
great to play with used for 1 month and ugraded to Utec noe Utec also for sell 450.00 shippe witch one you want
