First Logs, Evoscan stored DTC's
Just got my Tactrix and ran EcuFlash with succesful downloads.
My Evoscan also succefully loaded and logged.. Attached first logs on 3rd gear shows almost no knock (count=1 in few instances). Yet I had error codes in the DTC window which varied at each click of the 'Check DTC Present' as follows:
- Injector Circuit (rarely showed)
- Vehicle speed sensor (rarely showed)
- barometric Pressure sensor (rarely showed)
- Knock sensor (almost always)
- Egr sensor (almost always)
The logs show the readings..
Moreover and this is really newbie: Does clicking on 'Clear DTCs' put off the light on the dash? It doesnt in my case, is there any way thru Evoscan to clear the light on the dash?
Your comments greatly appreciated..
Thanks,
Wael
Thanks,
Wael
Wazz do you mind posting my logs here in this thread... maybe the tuning guru's can take a look and tell us what they think...and see if our (jdm spec) ecu's have different maps than the USDM spec evos
my car is not flashed..
mods include:
-exhaust mani
-3" dp
-3" catless catback
-works drop in filter
-boost controler set at 21 psi
respect
mods include:
-exhaust mani
-3" dp
-3" catless catback
respect
evo4mad
May 5, 2015 06:22 PM
SLYDOGRACING
19
Jun 21, 2009 02:51 PM
