IX Whp and Tq on Dyno Dynamics w/ TBE, MBC, and 20-22psi
What are people safely reaching on the Dyno Dynamics Dyno w/ basic mods like a TBE, MBC, and running 20-22psi. I'm getting tuned and I want to know what to expect from my IX. Some people are saying 320Whp w/ only TBE, MBC, and 20-22psi, but that seems high for only those mods at that boost and on Dyno Dynamics. I'm mostly interested in the Dyno Dynamics #'s cause that's what I'm getting tuned on and I've heard it's the most accurate.
Blitz DP
Perrin HFC
Fujitsubo RM01A Cat Back
Hallman MBC
Blitz DP
Perrin HFC
Hallman MBC
Don't know what the answer to your question is, but ideally you should get the car dyno'd completely stock so you know where you started from. Then compare that to the results after you mod. Use the same dyno for consistency. Honestly, the most important number is the difference between before and after.
What does the stock IX put to the wheels (Whp & Tq)? I'm not gonna pay just to find that out. There's no definitive answer to my post I just want to know what #'s the IX is safely reaching w/ minimal mods (Stage 1) on Dyno Dynamics specifically. And also the stock #'s to the wheels.
My buddy just got tuned at Vishnu on his 06 IX with a Vishnu Stage 1 kit ....Shiv pulled out 287 HP on the Dyno Dynamics.....not sure about the torque....evogriff is his evom username.
For comparisons, my 03 8 with a Vishnu Stage 1+ kit (264/272 cams) pulled 280 HP on the same Dyno Dynamics customed tuned by Shiv in '05.
Is that 287whp w/ just TBE and a tune? No intake or MBC? That's sick. I'm just trying to reach right around 290-300Whp. All these people reporting 320Whp are probably not on a Dyno Dynamics. The common 290Whp that I'm seeing on Dyno Dynamics is most likely equal to the 320Whp on other Dyno's.
check out www.norcalevo.net; speedelement and GST both tune on dyno dynamics, and most of their IX's hit 280-300whp on DD with tbe+mbc+tune.
