Missfire Issues
Your getting into higher harmonics, your getting closer to your peak torque. If you have access to a dyno. I would put it on the dyno and clear the code run the car try to cause the code if you can cause the code have someone run the car for you. Walk around the car while it's running and listen for vibrations. If you can't hear anything making noise you can use a sound probe. If you don't have a sound probe you can use a long stick or rod you place it to your ear and you can hear things inside the engine and tranny while it's running. Just try to use something non conductive and be careful around moving parts.
I get the feeling that it's not a genuine misfire.... Case and point, when looking at the logs it seemed that the engine just pulls timing like crazy out of no where and thinks the car is under extreme load (when looking at the load column it says 300, when that's technically not possible). Then, after it's pulled 10 degs of timing, it goes back to normal if you just take your foot of the gas and reapply it, stutter goes away for a little while. It seems that a sensor (maybe the knock sensor) or something is telling the engine that there's a problem, like a misfire, and it's reacting accordingly when there really isn't an issue.... It's odd that it seems to do it at the same time and same RPM at the same speed and not really anyother time.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
^^^^^ Absolutely correct. I have the same exact problem(as well as numerous other '03 owners) and finally got the only, and most logical, explanation from both dealer and "Road Race" veteran mechanics. The knock sensors' sensitivity pickup is set too high(manufacturer F'up) and unfortunately has not been recalled. Vibration from the "straight cut" transfer case is being misunderstood for a p0300 "multiple misfire" by the knock sensor, when in fact, there is no misfire. But hold your pants, there is a solution. All you need is a reflash to set the sensitivity down on your knock sensor. A very common and easily fixible headache among most(if not all) '03 Evo owners. Hope this helps ![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
That sounds like an easy thing to try lower the sensor values. Stand alone is an expensive option. And if there is a underlying mechanical issue a EMS would be a big waste of money. If you have a lot of miles on the car you might want to get your compression cheaked just to make sure the lower end is in good shape. Bad rod bearings could cause a P0300.
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Culled from 8 months of viewing, culprits and sometime fixes:
ECU reflash
plugs, wrong heat range
plugs worn
carbon tracking on plug ceramic
plug gap
plug wires
bad camshaft sensor
camshaft sensor not in spec ( giving correct shape of signal )
noisy lifters
lifter pump up
Transaxle noise, 5 th gear shift fork slightly bent or damaged
downpipe hitting lower brace
downpipe leaks
exhaust manifold leaks
real knock
boost too high causing real knock
poor gas quality ( more frequent than you think )
bad connect on coil on plug
worn motor mounts
transaxle noise due to insufficent fluids
EGR valve problems
very poor tuned flash
Take your pick
Milburn
i had this problem. my light comes on about ounce a month. i went through diff plugs, then went to some ngk 1 step colder. and they been working for me. my mods are bc272, headstuds, hpf licp, knn drop in,10.5hs, 3 dp, 3 cat back, rnr intercooler.
Case by case. I had Road Race in So. Cal flash mine. They said some Evos need lower sensitivity settings than others. Depends on how much vibration your specific Evo generates.
Can this sensitivity be adjusted with ecuflash? I have had the dealer flash twice, input shaft replaced (tranny), and new rings (piston), by the dealer under warranty...with no salvation... with 66K on the motor, I will try anything!
I asked my buddy, and he said it can be adjusted with it, but he's never done it. I have a UTEC on the way which I plan on running over my ECUflash.
as an update,
orginally had the ECU reflash and plugs changed.....
that didn't work, so I took the car back, changed out the wires and checked the timing, found it was off and replaced the belt and tensioner, and timed the car correctly.....
problem solved for a short period of time, with in 24 hours SES light was back on and the car was stuttering very badly, worse than before......
back to the dealership for another evaulation.....this time the replaced the input shaft in the trans and fifth gear......
picked up the car last night, no problems yet, knock on wood....took the highway to work today on purpose and nothing so far.....
lets hope that this works.....
apparently Mitsu has a recall for these parts as a possible fix for 03 with this problem, I will look into the work order #'s etc. and post them tomorrow....
