Need tune advice
Need tune advice
Getting my first tune this PM and have a couple questions.
Mods are TBE, cams, pump, LICP, BPV, K&N, & MBC.
As I understand it, the motor will handle higher boost and higher RPM, but doing both is perhaps unwise. I also understand that the rev limiter can be adjusted. Since I'm after max torque, does it make any sense to actually lower the rev limiter so I can more safely run at a higher boost level?
Any other tuning suggestions for max torque?
What is a recommended AFR in an extremely hot climate? Or does climate matter? What air temp compensation does the OEM ECU provide? Is a flat 11:1 AFR sufficient? Should it be enriched to say 10.5:1 above 5,000rpm?
Thanks,
Jim in Tucson
Thanks,
Jim in Tucson
Lower the rpms while upping the boost? Bad idea. You'll be wasting money, time and power. Your peak torque curve will hit at a much lower rpm then your redline but the hp production will continue to at least 6300rpms where it will either platuea or fall off slightly. Keep your stock redline.
You didnt mention how you will be getting the car tuned, but I would reccommend professional dyno tuning. They will be able to determine what AFR you car is safe at under load, trying to make generalizations with AFR's is something people do too often on forums.
One generality that I will accept is that 11.5 or below is usually safe, although not the most power inducing. Just let the tuner handle the AFR's and pay attention and ask questions as they are doing it! You will learn volumes of info! Good luck
Jim in Tucson
21
Sep 9, 2007 12:42 PM
Jim in Tucson
Apr 11, 2007 01:13 PM
