Which Reflash to get?
#34
If that were the case, there would be far less comment, if you have a look at some of the maps posted, you will see some really odd looking things, mass block of 7s in the timing map, high octane fuel richer than low octane, no boost cut. Not all of these are "pro" tunes, but the variety is interesting.
MB
MB
#36
MB -- Your posts (on this thread) could be construed as slander and you are getting very close to getting yourself in serious trouble. Jestr does not 'block' tune, has extremely high customer satisfaction, is extremely responsive, and his results are great. You are likely confusing Jestr with another tuner and should stop your slander immediately.
MB
#38
#43
just my 2 cents... I played around w/ a couple of Flash vendors, since there were a couple that were so popular on these boards. I made a lot of power on all of them... but my TTP flash was the safest and controlled my knock issue at high load & high boost. So i have to say TTP Engineering. =)
-Tom
-Tom
#45
-Tom
-Tom
