is it natural that u get richer AFR in higher gears?
Hi guys, this is on a 5 spd evo 7
3rd gear I'm getting 11.4-11.5
4th gear: 10:9-11:1
5th gear: 10:8-10:9
4th gear: 10:9-11:1
5th gear: 10:8-10:9
I too was thinking the same thing...Could you log what loads you hit in the respective gears and then look at fuel map to determine the cause?...I can understand a slight difference, but that is a pretty big swing...Also, I wonder what your 1st and 2nd gear AFR's look like...
Just based on the fuel map, .6 AFR would seem to be a big swing as cij911 says, could it be the change in ignition timing also has an effect? You can get 3 deg between cells, I know the ECU interpolates, but could it have an effect?
MB
MB
thanks guys... here are my posts... before and after tuning logs...
I think what u guys are saying is true... I do see higher loads in higher gears..
any comments on the log?
Car is: JDM EVO7
Mods:
1. K&N drop in filter
2. 3" turbo collector + cat removal + 3" TBE
before tune: swapped in walbro
log => https://www.evolutionm.net/forums/sh...=267797&page=4
Car is: JDM EVO7
Mods:
1 Post
Car is: JDM EVO7
Mods:
Car is: JDM EVO7
Mods:
