ApexI SAFC POLL - Please Respond
#182
This thread scares the hell out of me. I cannot believe it has not bee abolished so as to not screw up people's cars. It is never safe to take someone else's settings and put them in blindly without logging to make sure. Every car is different, whether it has the same mods or different mods, because conditions are never exactly the same (true octane, temp, humidity, leaks, etc).
#183
#184
Question for anyone, I have the Apexi TT as well, with the AFR hooked up and I believe I am seeing a setting on it that indicates voltage, would this be something similar to a logger or is this something I should just not mess with. BTW under WOT I have seen go as high as 1.05. Thanks
#186
Well I know Wartalon does not use a wideband to tune but does have a datalogger, I am curious to others opinions on this, obviously I wouldn't want to tune only on that but was wondering if it may be somewhere to start, thanks for the reply though.
#187
#188
what target range are you guys going after with 110 oct? im tuned for 11.1-11.5 at wot with 92 oct and tune for 12.0-12.2 on 110? can i go leaner than 12.1 on 110 oct? just wondering what others are seeing on race gas. this is assumeing your on the stock turbo and injectors
yellowman
Jul 5, 2005 02:54 AM
John4321
25
Apr 26, 2005 06:17 PM
Vivid Racing
24
Mar 24, 2003 02:16 PM
