Po172 Need Help
Po172 Need Help
Second time it came on. System too rich (Bank 1)
Mass air flow or 02 What is the best way to find the fault?
Was running at 3125 RPM when fault came on. Thanks
EVO 8
EVO 8
Readings
Long term fuel trim bank one -12.48%
short term was 94.38%
Air flow rate at 5.42 lbs/min
RPM 3125
Advance 29.0 deg at 1
Readings when fault went off freeze frame.
Any ideas ?
RPM 3125
Any ideas ?
Originally Posted by Ironwolf
Can the o2 sensor create a po172 making the Map look bad?
I got this code when I had a huge boost leak at the turbo outlet pipe to turbo flange. To late to fix it that night so I waited untill the next day and drove the car out of boost. I did throw that code anyway
