Speed Density with E-manage
I have a dodge stratus. It has the same 4g64 as the 3gen eclipse. Good bottom end, sucky SOHC.
I would have just gone ahead and flashed the EVO rom, which works for manual guys. But I have an auto for the time being.
The thing is that SpeedDensity is supposed to refrence IAT, along with RPM/MAP, and I couldn't find an aftermarket temp sensor that works with the E-manage. SO, now I just have adjustments for while in boost, and meter the air.
I'm running blowthrough, but my car is down for the moment. I have a 3" MAF, but I don't know the car it came from. Looks like every other GM MAF that I've seen, and just like you its just before the TB.
I lost compression in the 2nd cylinder. I have ordered good (budget) forged internals.
Have you gutted the MAF? If it's 3" there's alot on the table if you take off the screen and cut out the aluminum divider on the inside. Might as well if the car's down.
marco-ir
Lancer Engine Management / Tuning Forums
Jun 7, 2009 10:40 AM
