Losing your tune?
You both are correct I have reset my CEL by disconnecting the battery but the code was still stored in the computer when I went back to read it...the only real way to clear the code is with a reader
thanks for the replys. I think my MAF connector was loose I had previously been messin with the air box, its been running fine now. I reset it. Thanks again. If it returns i'll check the code.
There shouldn't be a problem with your flash when you disconnect the battery and the code would be saved on your computer, so if you need to go back to look it is there.
Only downside to disconnecting the battery is you lose your short term and long term fuel trims, and takes a little bit of driving to get them back.
If it is a problem where the code is always getting thrown like the CEL on a cat removal, clearing it once isn't going to keep it from coming back. My CEL just stays on. I check the codes about once a week. You can get you own code puller for about $80.
