Correct values for innovate lc-1 to emulate o2 sensor with test pipe DP
Hello.
I am planning to remove the first catalytic converter in downpipe and replace it with test pipe. I have also aquired a innovate lc-1 o2 sensor system and was planning to replace the original with that. It can as default already emulate original narrow band sensor, but since the catalytic converter is gone, the default values might cause CEL to go on. Has anyone find a suitable value range for the LC-1, so that the CEL stays off?
Thanks for any information
Cirrus
Cirrus
Yes I understand this feature. What I don't know is how much to scale the output values for the test pipe and I was looking for if someone has scaled numbers available already. But I think I'll manage to adjust it over time so that I will find the correct numbers.
yorT
Mar 4, 2010 04:17 PM
Jonas
Lancer Engine Management / Tuning Forums
12
Apr 15, 2009 04:17 PM
jamie_v1
Nov 26, 2008 06:16 AM
SwiftEVO
10
Jun 7, 2007 04:47 PM
