Autronic SMC 1.99 PNP EVO VIII IDLE HELP
Can anyone tell me if auto tune can fix my idle? the idle will bumb from 900-1400 rpm's...sometimes it will level out for a few minutes at around 1000. I turned the auto tune on, but because the idle will never stay put, the auto tune isn't doing its thing. Could this be in the tune? Or is it something else? Newely rebuilt engine; it has .7 miles on it.
Are you using the built in MAP sensor or the cars MAP sensor? Or maybe left it on MAF? what sise injectors and make are you using and what static pressure are you running? What cams are in there? Has the car been tuned or is this a DIY?
Its a simple ECU to tune but very complicate underlying algorythms are at play so the base settings need to be 100% right.
Answer these and email me your Cal file. Will send it back working.
Adelin
Adelin
Mark
WOW! you guys were a little late on the responses...sorry. I have the car running great now waiting to go to AMS for tune. Most of my problems were due to improper injectors settings and overall fuel multiplier. Its a built 2.0l, head is ported and polished, 269 cams, IHI TCW77 w/P22 Turbo, 1000cc injectors, autronic SMC 1.99. Thank You though
