05 slight modded any opinions on what next
it was tuned tuned at bushcur by the previous owner he said around 320 to the wheels i took it to the dealer and it has been gettign worse unfortunatley its clutch so i ordered the 4.3 fidanza one and it should be here today and i have the tactrix cable now too so i'll post some logs after the clutch is in i thini i should hav e alil mroe power for my mods, gsc s1 cams ams intake setup, ams fmic, and full 3 inch exhaust no cat, but i'll se eho wit runs after the new clutch is in
well thought it was clutch , but when i reset my ecu it seems to run fine none of those hesitation or slippage issues for a few days then it gradually comes back into the scene, possible ecu o rknock issue i did soem logs once the ecu was reset jus tnot sure how to post
