LC1 out put voltage question.....
ok so i have a LC1, and i want to hook up a gauge. (to the yellow wire.) ((ground on the same lugs as the LC1)) the gauge i want to use is the apexi TT, the voltage to a/f table calibrations are as follows:
A/F 10.0 12.0 14.0 14.6 15.0 16.0 18.0 20.0
o2 Volt 960 940 820 450 010 006 004 002
wich leads me to my next problem. what/how to scale the inovative wideband to accurately corolate that into te correct voltage for the apexi TT.
if anyone has done this some info would be great.
here's some links to where i have been getting the info for this:
http://www.roadraceengineering.com/i...structions.pdf
and
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
so far i have it hooked up via the yellow output wire from the lc1 to the white wire on the apexi tt harness. the apexi is grounded to the same spot as the innovative is. it works put i want to scale it so that it is a bit more accurate.
any info would be great!
and
You can use the LM Programmer software included with your LC-1 to set those values. Analog Out 1 is the 1v yellow wire output. I believe standard voltage is 1.1v @ 14.0 AFR and .1v at 15.0 AFR. You can simply change the voltage @ 14.0 to .82 and it should match correctly.
SLVRNBLK
Sep 16, 2014 11:26 PM
s78
Jun 13, 2010 04:00 PM
