Zeitronix boost sensor problem
I'm am having trouble with my Zeitronix ZT-2/3.5 bar MAP sensor combo. With the car off, it reads -7.0 or so and with the car on it reads a steady 25.50 no matter what I do with the throttle. Does this suggest a particular problem to anyone?
I installed this a few months ago but haven't really used it until now. I can't remember whether the boost sensor was working before or not. It does datalog AFR and RPM without a problem.
Thanks.
Thanks.
I have a boost gauge on my EBC, which shares the same boost source. I am using the Zeitronix +5v output. The wires out of my Kavlico boost sensor are white, black and red. I'm assuming that the white is the signal wire. Black is to brown sensor ground on the ZT2 and red is to the yellow +5v wire. White is to the ZT-2's orange wire.
Casey Robertson
Mar 22, 2016 04:32 PM
