evo 8 map
evo 8 map
I would like for someone to take a look at my map. i have been working on my own tune, for a bit now. but for some reason, i keep hitting knock in the higher rpms. consistant 4-6 counts
just recently i down shifted into 3 and punched the gas. Got a cloud of black smoke (grayish smoke) and knock showed 30 on the commander.
If i just get onto it in 3rd minimal smoke ( since i am still running rich) and the 4-6 counts. Should i pull ignition first, or just add fuel and bump up the ign?
If you are referencing the knock level as indicated by the commander then you dont really have much to worry about: 4-6 counts is nothing and simply engine noise. 30 is obviously a bit higher but on the verge of being acceptable. If you see over 35-40 on a consistent basis you need to check fuel and ignition and go with a more conservative tune.
The PFC has a warning when knock count goes above 60. In my experience you can get up to 60 but not have any real knock from listening to the det cans but 20-30 peak knock counts is nice and conservative.
Cool thanks for the reply. I will send you the map i have currently in my car. My wideband went bad, so i have not been able to do any tunes. That event only occured that one time. has not happened since then.
But I am Running REALLY REALLY RICH. to the point where fuel is actually comming out of my exhaust, along with the Black cloud or richness.
Not 100% sure if i have to adjust my Base Map and then go from there.
bsbllfit7
20
Sep 28, 2015 05:07 PM
