Hallman Pro vs. Hallman Pro RX
A buddy of mine and I are both running the Hallman Pro. Boost is rock solid. According to the Hallman site, they recommend the RX for applications seeing less than 5 psi from wastegate pressure. It has a lightweight ceramic ball. but if you get a RX, it'll come with both *****..so it's switchable
I have found the Pro is much better for cars making relatively high boost like Evos
the RX is best suited for low boosting cars like n/a cars with an added turbo - like 3 - 8 psi
The Pro is a unit that works really good
Al
Al
either one should be fine, i guess. the RX kit has all the Pro parts, you can switch out to meet your needs. i can't wait to install mine.
dreamevo
Apr 15, 2005 01:59 AM
