evoscan 2.4 not working with aem wideband but version 1.0 does
evoscan 2.5 not working with aem wideband but version 1.0 does
hey guys I just purchased evoscan 2.5 as an alternative to mitsulogger. Mitsulogger never has once let me down even when using my aem wideband. I bought evoscan less then a half an hour ago and version 2.5 refuses to log when i have the wideband box selected it starts logging then immedietly shuts off saying something about object refrence..... I decided to try an older version of evoscan version 1.0 and my wideband works totally fine. but 1.0 is somewhat buggy when it comes to analyzing logs and id much prefer to use the newest version that i wanted in the first place. Is this a common error?? please tell me there is a small fix for this, this is really bugging me
I am using EvoScan 2.5 with the AEM wideband for logging... Make sure your COM port is correct. When I upgraded from 2.0 then 2.4 I needed to change the COM port again... if you are using Windows, go to the device manager and check which COM port your serial USB cable is using, then change to that COM port on EvoScan. I hope this solves your issue. Please let us know...
luvnish
12
Apr 13, 2009 06:03 PM
evo4mad
Oct 12, 2006 11:30 PM
