Stock Evo with MBC - what psi to set?
Ok, I have searched and searched but not finding a direct answer to this question.
I have purchased a Buschur Racing MBC, ETS LICP and K&N Drop in. All just installed on my Evo 9 IX MR
My future mods will be a BR 3" TBE and a Reflash.
Right now I just want to set the boost pressure at something decent but safe until I can match the fuel w/ the Reflash.
I have read the MR boosts stock at 21 psi, then tapers to 18 at redline. My concern is that if I set the MBC to 21, then it might run too lean at redline since it wont taper anymore like the factory boost solenoid did.
However if I set it at 18 psi to be safe, I am missing out on 3psi boost.
I do not have any guages other than stock to monitor AF ratio or EGT for safety. What does the forum recommend for boost pressure setting on my MBC
blackevoVII
15
Aug 30, 2004 11:26 AM
