How to tell if my engine is running too lean or too rich??
if it sputters with smoke, its rich or burning oil...
if it sputters and tries to die but no smoke it could be lean...
If the tailpipe appears "wet" inside and you touch it and it smells like unburnt gasoline you're either really rich or have a spark issue.
Another option is to hook up evoscan and see your fuel trims.
Overall, the best option is to get a wideband.
*note* I'm no expert, this is just my opinion!~
Wideband Without Asking....plus If You Want To Try Your Luck You Could Try To Check The Spark Plugs...put New Ones On The Car Take For Rip And Take Them Off And There You Can See If Black To Rcih If White Too Lean.......got To Be A Little Brown Color...that Is My Two Cents....i Hope You Guys Agree...
i think if you have to ask what a wideband is, then this is not the right forum for you and you should not be doing work of any kind to your evo... http://www.rccars.com/........ i think you should start modding one of these before you start working on anything over 50cc lol...
