tactrix cable question
Hi
I'm thinking to flash my ecu but don't know what cable i have to use, i did a search and i found these ones
Tactrix openport 2.0
openport 1.3U
openport 1.3M
What is the difference between them? Which one i have to buy? Which one works better for EVO 8?
openport 1.3U
openport 1.3M
Thanks for the replies, i will buy the 1.3 one but where can i buy it? i found it in these website but don't know if it works http://www.limitless.co.nz/Cables/
Someone know where can i purchase openport 1.3?
Good Luck
The link you have works but is slow to receive as it comes from New Zealand and the author of Evoscan. you can also buy cable from tactrix.com which is Colby author of Ecuflash site I believe . http://www.tactrix.com/
Good Luck
Good Luck
Thanks for the answer, in the tactrix site the openport 1.3 is no longer available, Where can i find the openport 1.3 beside from New Zealand?
Someone knows where?
one from new Zealand took 8 working days to receive after 12 days of processing time.... There was somebody selling it at the classified forum.
So do these limitless cables work the same as the tactrix cables? I thought I read elsewhere on this forum that they for sure did not act the same. The tactrix had worked much better?
krisdlm
May 30, 2014 11:14 PM
