Unstable idle, car almost stalling at low speeds, need help
If I increase it by 1 increment it increases by 47. So do u want me to do 3 increments? It will go from 508 to 648.Or is there a way to increase by 1? Sorry for maybe dumb questions. My first time modifying the rom. Thanks
Maybe later a speed density setup will stop the issues i had with the small lope in the idle from effecting the MAF sensor.
I had a AFR swinging issue when i had a metal intake on my car with injectors and cams. Solution was just simply to put the stock intake back on the car .
I will try adjusting Idle Stepper look up table.
