Pfc with New Map sensor(3.5 bar)..
PowerFC with new Map Sensor.(Avcr 3.5bar)
Do we need to reset the Pfc for it to read the Idle with new Map sensor?
I have enter the scale/offset for the map sensor Avcr(3.5bar)( which have the right amount of Boost(psi) with the meter that I am using) but I found out that the engine run a bit rich after I install the new Map sensor is that normal? Do I need to remap the Pfc with the new Map Sensor.
Pls enlight me.... Thank you.
Well. I am using the AVCR 3.5bar now, and doing the tunning at the moment. so far I am sure u can use different Map Sensor, where AEM 5bar look like a nice Upgrade.
But u need the calibrate the Offset and scale for the new Map sensor...
AVCR 3.5bar is the Solenoid valve that come with the AVCR boost controller?
