AEM WB02 vs ProSport WB02 - Logging question
I currently have an AEM WB02 gauge (uninstalled), but I have a few ProSport gauges already installed. ProSport now has a WB02 available, which wasn't available when I bought my AEM WB02.
http://www.machevo.com/prwiaigakit.html
It uses the Bosch 5v O2 sensor. Does anyone know if this is the same as the one used in the AEM UEGO WB02 ... and particularly, if it is the same, does that mean that EvoScan will log the data the same way? I don't want to buy it and have it not work with EvoScan correctly.
Thanks!
Thanks!
Thanks!
Thanks!
Stick with the AEM until the new prosport comes out, or just stick with the AEM period...
No not the same sensor that the AEM uses, and if you get a prosport gauge then no you won't be able to log with it because the prosport doesn't have a 0-5v analog output. I just got off the phone with prosport and they are supposed to be coming out with a wideband that will also have a 0-5v analog output for dataloggers in late summer2009.
http://prosportgauges.com/wideband-a...ratio-kit.aspx
ProSport does use the Bosch sensor just like AEM. ProSport uses the 4.9 one, and AEM uses the older 4.2 (thought new ones may use 4.9 ... mine has a 4.2 @ ~2yrs old).
I'm not sure what moron you talked to at ProSport, but their wideband O2 gauge is out and has been out for months. That makes me question when they say there is no 5v output. I guess that's what I need to find out....
stokEd
51
Oct 14, 2015 06:44 PM
mrm95
11
Sep 7, 2015 06:40 PM
jameswwt
Apr 22, 2012 09:20 AM
