Autronic EVO8 pnp peak & hold possible?
Hi,
I have one question about the EVO pnp Autronic boards:
Can the Autronic run low impedance injectors without the Mitsubishi resistor pack? I mean to say does it do peak and hold? I'm running 1850cc injectors on the stock ECU, but the stock ECU is having difficulty opening the injectors using saturated injector driving methods (limiting me to 30psi fuel pressure!). I need to go peak and hold and ditch the resistor pack altogether, and Autronic is one option. I had a look at the software and there seems to be a choice of injectors in the list (and that includes lowZ and highZ). I'm just not sure whether the injector drivers used are saturated or peak and hold, or maybe they do both?
Thanks in advance.
Thanks
Thanks in advance.
Thanks
