EVO Injector Upgrade
im gettin busher stage 3 head. and turnin up boost to 28 psi. dont want boost to stall..
also have a question for u. i was drivin my evo home the other night a was at 4000 rpm's and like 15lbs of boost when the engine cut out for a second. now i have this tiny tick all the time. the tick speeds up when i rev my engine. but the weird part is my engine runs and idols fine. any ideas?
Tiny tick can lead to a big problem, could be cam related or something internal. Take it to a shop to investigate.
As far as the head upgrade and boost, you are pushing the limits on a stock non meth/e85'd motor. 93 oct and 28psi stock turbo you may consider alternate fuel or have a nice race intercooler(garret core - buschur race/ams)
Even if you stepped up to the next size injector, 650cc's, your car would run like crap. Any injector upgrade requires changing injector scaling, latncies, and fuel maps. And if you you can do this, you have the right monitoring equipment, and you are tuning anyway.
You also can't raise the boost that high with out changing the boost limit in the ECU.
The good news is that you can get the Burshur stuff you want, or need, with the stock injectors if you just just keep the boost down and everything you need to know about changing things in the ECU can be found here;
https://www.evolutionm.net/forums/ecuflash-179/
FS[South]: Injectors greater than 1200cc
apexcutter
Feb 12, 2017 12:08 AM
SS2EVO
21
Nov 10, 2011 08:15 PM
jameswwt
Dec 16, 2010 12:27 AM
