How do i fix car shuting off with ac on when rolling to a stop and pressing in clutch
Old Jul 14, 2010 | 12:04 PM
Dr.Sound's Avatar
I'm on a MAF, using 91 octane. Lighter flywheel. GSC S1 cams.
car idles fine with AC on.
Raising the idle will not help, at least in my experience it did not. as a test i bumped up RPM with AC on to 1500RPM and the car still stalled while coming to a stop.
Old Jul 14, 2010 | 12:36 PM
myev0sneezes's Avatar
I have the same cams as you but im using 93 octane. I just got tuned the other day and now i'm facing the same problem. I noticed it happens when im in a higher gear(4th/5th) step on the clutch and drop it in neutral. The idle falls hard and tries to pick it self up. On occassion the car stalls.
Old Jul 14, 2010 | 12:58 PM
bigturboevo80's Avatar
Yea i noticied the same thing today idle increase is not really helping.
Old Jul 14, 2010 | 01:05 PM
HornstarBU's Avatar
Did anyone try adjusting timing a little to see if that helps, just in the lowish rpm range?
Also, no vacuum leaks, good alternators, good battery, right? And no CEL's either, right?
Old Jul 14, 2010 | 01:06 PM
vtec2mivec's Avatar
I have same mods too, I was searching for something to help, I'm going to get retuned again soon, but mine will turn off when I'm coming to a stop if I decelerate quick. I've been heel toeing to keep revs up
Old Jul 14, 2010 | 03:46 PM
Dr.Sound's Avatar
Yes.
Last night I've bumped my timing 3 degrees on both hi and low octane maps in the following area:
0--------100
3000
Same result. Car stalled.
This morning i've done the following:
- decreased AFR to 14.4 in the same area as above
- bumped idle with AC on to 1100
On the drive to work i was trying to make the car stall. It did not. I will give it 2 days and report back.
And no, no CELs. Good alt, batt, vac.
Old Jul 14, 2010 | 03:54 PM
Appauldd's Avatar
Raise the ISCV A/C on steps in the 2 hottest cells by 10. Problem solved.
Old Jul 14, 2010 | 05:02 PM
Dr.Sound's Avatar
I did this, thank you. I will try and report back.
But, isn't that only in neutral? Since the table is called: Desired ISCV initial step position with AC on - Neutral.
What if I am slowing down and press the clutch in WHILE in gear? Does the car interpret that as neutral?
Old Jul 16, 2010 | 12:35 AM
did it work for u?
Old Aug 3, 2010 | 01:56 PM
evo4life400's Avatar
this used to happen to me really bad!! my tuner adjusted the idle and it's a little better but it still does it sometimes when I let off on the gas fast and push the clutch in. I read something somewhere about a mod in tephra that affects this...can that be true?
Old Aug 19, 2010 | 11:22 PM
PlanoEvo's Avatar
read my thread https://www.evolutionm.net/forums/ec...ng-issues.html
Rpf1evolution (Jan 20, 2023)
FastAzzEvo
May 16, 2017 05:46 AM
Evosick2332
Dec 7, 2012 09:58 AM
migs647
Northwest Region
177
May 31, 2012 07:54 AM
joedr
Aug 22, 2008 02:11 PM
Quick Reply: How do i fix car shuting off with ac on when rolling to a stop and pressing in clutch
